January 22, 201412 yr Hi, I'm on the point of buying an MT03, and I don't think it has a 12v lighter type socket for a satnav or heated gloves etc. How big a job would it be to fit one do you think? Is it even possible? tia
January 22, 201412 yr I fitted one to my SR125 with no problem. You'll need an inline fuse to cope with whatever you are running and probably best to run the live from a wire from the ignition so it's not permanently live. I fitted mine nearly a year ago using mainly to charge my phone but pretty much use it as I would the one in the car and had no issues. I have seen them overheat but I suspect faulty wiring/earthing to be at fault.
