January 19, 201412 yr hi there i have a yamaha dt 50 0n an o3 plate was running fine then stopped pulling as good and will only do 20 mph now so ive put new pistonkit new gaskets new plug fresh petrol and is still the same 20mph max and struggles to maintain speed anyone help much appreciated thnx graham
January 19, 201412 yr Moderator I thought this was about pulling girls!! I would have said get a bigger bike
January 19, 201412 yr Moderator might be a fuelling problem? Check fuel flowrate to carb, how does pulling the choke on affect it?
January 20, 201412 yr Post an intro dude, that will increase your replies for sure. pull the choke on and see if it helps.
January 20, 201412 yr Author might be a fuelling problem? Check fuel flowrate to carb, how does pulling the choke on affect it? new to this site but pulling the choke on cuts bike out
January 20, 201412 yr Author Next thing to try is remove the air filter element done that still the same thanks graham
January 20, 201412 yr Author I thought this was about pulling girls!! I would have said get a bigger bike i have a suzuki gsxr600 the dt50 is my 16year old sons
