January 8, 201411 yr hi there i have an 09 YBR 125 ESD, the rev meter/tachometer is not working anymore,it won't show above 5000 rpm(even at full taps),it used to work fine,ive already checked battery conections,and cleaned out dirty connections in the plugs behind the tachometer,I'm not shure if the rev gauge is mechanicaly driven off the crank,or if it is electronic...I prefer working on the bike myself so if anyone can suggest a DIY sollution for the problem...PLEASE HELP!!! - regards from SA
January 9, 201411 yr If its mechanical" they"l be a cable,,,,if its electric,,, it will be goosed,, or find where the pick up is,,, buy a manual
