Hi guys need some help please :)
And replace the seal and washer
  • Replies 198
  • Views 25.7k
  • Ok your making this difficult you have to many different post about this running problem. Copy and past them all into 1 thread to follow and keep it as 1,trying to follow and narrow down the probl
  • Ahh right no it smells swweeettt like a 2 stroke and on this its just clutch basket off to change that seal so hopefully its just carb issue fingers crossed
  • Lol my bad too lean hope you forgive me 0:-)
Whats the verdict on the screw seal dt502001 could that be adding to my problems
Sorry just seen your reply ok ill get a new seal and washer for it cheers guys gives me summat start with again bloody bike
Bike was running ok on a short ride after i had done all the above things then bike started bogging out with choke on and with choke off now it wont start im going to check plug and check fuel flow tomorrow
If thats what u ment airhead
Yeah had 3 or 4 short runs without cutting out and i was opening it up full revs the only slight issue was a high idle at 3-4k it cut out when i put choke on but i assumed that was normal with engine being warm but wen bike was idling high i tried to adjust the idle screw and it didnt really change much it was either high idle or wen i adjusted screw out at small alterations it just dropped to almost cutting out and i had to flick choke back on for a second for it to keep running if you understand what i mean iv just ordered a new standard air filter aswell just to eliminate that as an issue
I take it that was the idle screw , you backed off" large knurled edge, not the air screw[ small cross head ] ?
As the idle screw just raises and drops the slide. a small amount should not cause engine to die,
Now you have a air leak somewhere possible causes carb not tight ,reed valve not sealed,intake cracked, left crank seal.
edit
Or what blackhat said just read it.
the only slight issue was a high idle at 3-4k iwith engine being warm
Was the idle fine when engine cold, ? how old is this DT
Were on the same track DT50 " :yeah:
Yeah the idle screw i was adjusting all the fittings are tight and well sealed iv used gasket gasket sealant on all the intake and reed valve side the inlet looks in good condition i cant see any cracks or holes in it anywere the bike is 1999 t reg and how do i check the crank seals iv read about spraying carb cleaner in to the engine casing were stator plate is is this the way to test it and whats ment ro happen also as i said before i have a rubber o ring and washer missing from the mixture screw and im not 100% sure if there is 1 on the idle screw
The bike idled high when i 1st start it but settled down to around 2kish when i bliped the revs just starts messing up when i ride it
Oooh uf u guys get me to the bottom of this your on my xmas card list for sure :)
I havent checked the security or condition of the expansion bottle that goes in the inlet manifold either so ill do that aswell
Yeh" spray behind the flywheel with an excelarent . [ WD/ Brake cleaner/ carb cleaner/ ] while bikes running " if the seal is worn / hard. it will pull excelarent into crankcase, and revs will increase , was the bike unused for a spell , ?
The other seal R/H. pulls gear oil thru [ when worn] and smokes heavily,
Ok ill check that iv noticed that it looks asif its been spitting oil out of the exhaust maniflod and on to the numberplate at back you think this is crankcase seal issue then
And are there any tell tales with the oil e.g looking milky
