Hi guys need some help please :)
Sorry dt502001 i no i get all excited with my issues lol but i think iv fixed it now was a carb issue i did a lame ass job of cleaning it i didnt take all jets out the choke or the idle and mix screws out either its was filthy inside those ports i got the trusty haynes manual out to sort it iv ridden bike today seems ok on a short run no cutting out or anything so fingers crossed its fixed thanks for all your help everyone if anything goes wrong ill let you no and try not to act retarded chasing balls lol
  • Replies 198
  • Views 25.7k
  • Ok your making this difficult you have to many different post about this running problem. Copy and past them all into 1 thread to follow and keep it as 1,trying to follow and narrow down the probl
  • Ahh right no it smells swweeettt like a 2 stroke and on this its just clutch basket off to change that seal so hopefully its just carb issue fingers crossed
  • Lol my bad too lean hope you forgive me 0:-)
:eusa_clap: Well done hichy" its a learning curve, hope she rides :yeah: well now,,
Me to iv been havin nightmares about carbs n jets lol
Yeah thanks to all your advise on here your my heroes :D
:thumb: Live and learn next time you say you've cleaned the carb you will be able to say "you cleaned the carb" not just blew some cleaner around and can see why it so important to fully clean the carb.
also good you have a sence of humor and could see where I was going with why you were having trouble figuering this out.
Me too - I was quite apprehensive about stripping mine down til I got inside it and saw just how simple it really can be! Now runs as sweet as :) (With a bit of help from the guys on here who've been there, done it etc!)
Hiya guys still got same running issue of riding then cutting out the jobs iv done are
Air filter cleaned and oiled
Carb fully dismantled all jets and ports cleaned choke cleaned
Mixture screw port cleaned
Idle screw port cleaned
Fuel tank cleaned
Fuel tap cleaned
Inlet manifold cleaned and resealed
Any ideas of what to try next thought it was sorted yesterday but its being gay again :'(
Iv got a haynes manual and it shows on the mix screw a washer and rubber seal but mines doesnt have 1 on the mix or idle screw could this be an issue sorry if im bouncy balling again dt502001 lol
Pull the fuel pipe [ tank] run it into a jug. see if flow is interupted. :eusa_think:
Ill try that iv had tap out and cleaned it though and it does it if fuels turned on or on reserve plus the bikes now not running again
Ok how the spark?
Wait the screw is missing the seal and washer,,what about the spring without it the mixture secrw can vibrate out and mess with you mix.
Edit check the amount of turn it's at now vs what you set it at.
Yeah no seal or washer on the mixture screw wasnt on when i dismantled carb like my diagram showed me i checked in the port and it wasnt in there the spring is on though
And i think spark is ok going to double check tomorrow and fit a new plug aswell to eliminate that issue
Bike was sparking last night though
Yeh" but the coil may breakdown once hot, lets try the simples first tho..
Am thinking dirt in fuel tank, :eusa_think: as it ran well for short time, now carb could be choked again . run fuel into CLEAN container
Iv had a spark bulb on the plug and spark seems fine constant light no breaks in it even when warm but ill test fuel tomorrow and check spark aswell again
I took the spark tester off lastnight but ill refit tomorrow
