I put that in 1st but after a ride i left bike stood up straight and let it settle and inspection hole was empty thats y i put more in i thought it had lost oil somewere but ill start again ill empty it n fill it up again
  • Replies 198
  • Views 22.5k
  • Ok your making this difficult you have to many different post about this running problem. Copy and past them all into 1 thread to follow and keep it as 1,trying to follow and narrow down the probl
  • Ahh right no it smells swweeettt like a 2 stroke and on this its just clutch basket off to change that seal so hopefully its just carb issue fingers crossed
  • Lol my bad too lean hope you forgive me 0:-)
Yeah ill do that 2moz hopefully ill get 2 out is it better to drain in stand or stood up straight
Cheers air head ill let you no what happens 2moz 1 thing after another this lol or its just my non comprehensive lack of common sense lol
Yeh hitchy " is the sight glass clean, are you seeing the level, :eusa_think: And hope your keeping the 2 stroke tank topped up,,, different issue , but just remembering you,,,
The sight glass is clean yeah i can see the oil when i put it in but wen i kick bike the level drops and eventually all seems to dissapear and not returning back into inspection hole and yeah iv got 2stroke oil in bottle but thanks for reminder on that 1 lol
Well thats a strange one. :eusa_think: As in a stroker its only gearbox thrashing it around , should settle quickly. not like a fourstroke and pumped round engine, [ top end etc] thats why 4strokes take a while to settle level,
I thought it was strange aswell thats y i put more oil in i havent run it though jus kicked it over with ignition off and watched the oil level i havent a clue were its gone im goin to check for visual leaks tomorrow but it was empty after i kicked it over around 20 times so god nos were its gone lol
It's not gone anywhere far away, I'd guess that the clutch rotation has thrown the oil out of the clutch casing into the gearbox casing and because the oil is cold and thick (viscous) then it will take time to seep back to the clutch case which is where the inspection window is? This is why you check with a hot engine ;)
Sounds logical to me air head ill drain it tomorrow see what comes out "watch this space".........
I've had bikes that for some reason you had to lean to the left and then stand straight to get the oil to show up in the window,but as air head said just put in the right amount and don't wory to much about it.If your output shaft is leaking then fix it so you dont have wory about the level droping.
Theres no leak from sprocket shaft n iv drained oil ill jus put right amount back in and leave it cheers guys
Iv done all jobs on it now set float to 20mm no fuel leak no oil leaks ticks over perfect without choke on cuts out when warm with choke on pulls in every gear so i think finally i am victorious and you were right about the oil air head were it had settled so cheers every 1 again so happy bikes sorted i got a non runner running with your help so just got mot check list to do then get her on road :D
Ano yeah gunna do top end rebuild next month i can do them tho without help lol so hopefully im all good thanx again guys the world is a better place because of you guys on here
So hows it running ???? Blow up yet?
Lol cheers for optimism dt its fine on little trips no issues just waiting for output seal to come then i can get it motd and on road it seems fine though at moment :D
Bike passed mot couple advisories well happy and it aint blown up yet dt lol im gunna derestrict it though now cheers guys
