1992 TDM 850 grinding noise
Kieran Devlin
This post is 3974 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi Kieran, might be anything mate, where does the noise come from? Have you checked your wheel bearings for instance or even something rubbing. If it's your clutch then you have to have the cover off to see what's going on unless you can see through aluminium, try it on the centre stand in gear and see if you get the same noise cos with the best will in the world "I have a grinding noise" is not much of a description mate. Also it is usual to say Hi on most forums (new members section) before asking strangers for advice, bit like when you meet someone down the pub you don't just ask a total stranger how to fix your bike before you say hello do you? Welcome to the YOC by the way it's always nice to have new folks join in and stick around for a laugh, we get A LOT of one hit wonders here who just want an answer and then dissapear never to be heard from again till their bike goes pop.
Drop the oil" see if its grey in colour,,, then investigate, [ pull the clutch cover,],,
