December 28, 201312 yr The other thing Grip Puppies do, apart from dampening vibrations, is they make the grips thicker, which helps a lot with tight grip induced pain. A thicker grip handle also helps you relax your grip more, you just naturally tend not to grip it "for dear life".
December 28, 201312 yr Author great response on this guys...thanks took the bike out for 20 mins today and relaxed and kept the grip 'loose'..no issues this time,will be out for a lot longer tomorrow so will see how I get on then,will adjust brake position also I think these grip puppies seem to have a good rep by the sounds of it
