2 stroke lawnmower oil
mcnamara1710
This post is 3816 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Is better than nowt" :yeah: a member on 2 stroke forum put diesel in his autolube tank ,as he ran out, got him home,,as diesel is oily,
I mixed all the diferent oils [ mineral/ fully/ semi synth.] in bottles a few year back . i shook them up, left them for a month, and they never conjealed or separated,, :eusa_think:
Minneral 2t oils have different ash content depending on what they are used for,not saying you cant use it but best to use the free suff in something like a lawn morow than blow up a good bike eng for the sake of a few bucks.
Most companys die there oils so they are easly reconised and has nothing to do with the quality. EG belly ray has alwasy been blue,royal purpel is purpel,castrol is greenish
What you need to look at is the rating of the oil thats the roung circle on the back and has letters in it as long as it meets or exceeds the requirement's set by the factory then its good
Edit sfg can be used in a eng requiring sff but not in a eng needing sfh and sfh can be used in both of the formentioned eng's.
Thats why synethitic oils have become so popular they just about go with any requirments and mix well.
API = american petrolium instute.... ios = international standerds. The rest I copied fromhttp://www.commaoil.com/productsguide/view/6/267/TST5L NOTE THE SHELF LIFE it might be bad by now if not stored proprely.
TWO WHEEL
2 STROKE MINERAL
APPLICATION
Low ash mineral oil for two stroke petrol engines (motorcycles, mopeds, cars, lawnmowers etc)
requiring an oil of this type and quality level.
Good lubricity through specially selected mineral basestocks.
Helps prevent spark plug whiskering and corrosion.
SPECIFICATIONS
API TC
JASO FB
ISO-L-EGB
TYPICAL INSPECTION DATA
Specific gravity at 20°C 0.880
Viscosity @ 100°C 10.9 cSt
Colour Green
IMPORTANT
The engine manufacturer’s recommendations on mixture ratios should be observed.
HANDLING
Avoid extremes of temperature.
Store under cover.
SHELF LIFE
Five years from date of manufacture.
Date of manufacture can be identified from a five figure code printed on the bottle. The first three
