Hi folks
A question for you that I've asked elsewhere, I want to fit R1 blue spot front brake calipers to my FJ1200,
a fairly standard mod.
The question is, are Fazer/R6 front calipers the same as R1, I know they look the same but do they give the same improvement in efficiency?
Seen a set on ebay cheaper than R1.
Thanks,
Big Bob :)
Bob,
They Fazer thou uses the same engine as the R1 only it is de-tuned.
I suggest ringing you local Yam dealer and ask them if the part no's are the same.
As you know differnet model bikes use common parts as I found on my Yzf750 and the XJR1300sp when I owned one!
Regards
Rob.......
they are the same ;)
Thanks, Beezkneez, I'm off to ebay for a look. See you out there sometime.
Big Bob :D
  • 5 weeks later...
:D I got a set of R6 calipers off ebay £33.20, fitted them & a big improvement over the standard ones.
Next question, has anyone tried Armstrong pads, seen them on ebay, any good?
Thanks again
Big Bob
EBC's mate..got myself some tests pads from a friend there ;)
double H sintered
Yep the double sintered win hands down! B)
