Spark goes off while riding - Virago xv125
Novice thoughts here - wouldn't be something as simple as the wrong heat rated plug or incorrect gap?
Ok klume so the bike could sit and idle all day and not have the problem and it only happens when you ride the bike?
Thinking back your bike should have a clutch saftey switch any road bike built after say 1980 has one someone has removed it.
Just checked a XV125 owners manual, they definitely have both side stand and clutch switches in the ignition circuit, as does the XV250
Symptoms sound similar to the problem I had recently on my Radian, cut out on me 4 times riding home from work, re-started every time agian on the button, found the clutch switch faulty
Check the clutch switch out agian kelum, if its been removed, find out how/where its been bypassed
Yes only when I ride.
yes , someone has removed it...the whole left hand side switch set, clutch leaver have been replaced with a one that doesnt have room for a clutch switch..
Ok lemme check...btw, do you have an xv125 manual?
