December 20, 201312 yr Hi all i have a 6v battery on my yamaha,when connected to a volt meter in idle tick over.it reads 8.5 is this correct many thanks.
December 20, 201312 yr Moderator I don't know if that is sarcasm or not? It is definitely wrong, as the revs increase the voltage across the battery will too. If your battery is in good nick you need to replace your voltage regulator. Replacement is the only real test. You could be looking at as much as 12 maybe 14 volts at high rpm. Goodbye bulbs, goodbye battery.
December 21, 201312 yr Yip mac... find where its located,, reg/rectifier unit,,, it should be 7.5 volt max... I think your bikes been tampered with , as u said a 12 volt battery was fitted.. Read this post,,, http://www.team-bhp.com/forum/motorbikes/69718-yamaha-rx-100-queries-4.html
