December 17, 201311 yr Hi guys pls help.i changed my sprocket and chain today and had to take off my gear shift.after putting it back on can not get any gears what have i done wrong.i have found neutral but my light does not come on.but no other gears pls help what i have to do thanks in advance.yamaha rxs 100 i have.
December 17, 201311 yr Author Hi airhead.yes gear leverand the seround case by stator.also case where my clutch cable goes into to get to the varator nut.
December 17, 201311 yr Moderator what's a verator nut? cant think why you cannot select gears though, what none at all?
December 17, 201311 yr Author I took everything off to expose the nut to take off.the nut that keeps the front sproket on.when i put it all back and the gear lever nothing,my bike was stuck in gear and could not shift up or down.
December 18, 201311 yr Moderator I took everything off to expose the nut to take off.the nut that keeps the front sproket on.when i put it all back and the gear lever nothing,my bike was stuck in gear and could not shift up or down. you have to rock it back and forth to be able to change gears...are you doing this?
December 18, 201311 yr Author I've not done that airhead,at the monent it is in neutral.so i will put gear shift back on select 1st gear if i can.if not rock back and forth.will this inline my gears back to normal 1 down 4 up.thanks
December 18, 201311 yr Moderator it is not possible to select gears when the engine is stopped without rocking the bike back and forth
December 18, 201311 yr Author Ok airhead thanks.I'm in work at the mo will try when i get home then.will let you know how i get on.
December 18, 201311 yr Mayb you did not put your gear lever in in original place mayb I had a old pit bike years ago that I done it to and would not go in gear till I got it back in the proper place
December 18, 201311 yr Author Dr rich maybe it could be that,how did you get over that.put it on and check,and if not take off and move slightly and so on was it.
December 18, 201311 yr Moderator just make sure the lever doent hit the frame or the engine casing when you move it
December 18, 201311 yr Dr rich maybe it could be that,how did you get over that.put it on and check,and if not take off and move slightly and so on was it. Yep that's how I done it don't take to long next time get a tipex pen and mark it so u no where it lines up if it is that
December 18, 201311 yr Author Airhead and dt rich.thanks for your help,i did what you said rich took 3 attemps but all sorted now thankyou.
December 18, 201311 yr Normally there is a mark on the splined shaft that needs to line up with the split in the lever Ride it for a couple of days, if its still good, then mark the end of the shaft with a centre pop, where it lines up with the split. That wont wash off
December 18, 201311 yr Airhead and dt rich.thanks for your help,i did what you said rich took 3 attemps but all sorted now thankyou. Good glad you sorted it
