help pls to get back my gears
mcnamara1710
This post is 3983 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi guys pls help.i changed my sprocket and chain today and had to take off my gear shift.after putting it back on can not get any gears what have i done wrong.i have found neutral but my light does not come on.but no other gears pls help what i have to do thanks in advance.yamaha rxs 100 i have.
Link to comment
Share on other sites
I took everything off to expose the nut to take off.the nut that keeps the front sproket on.when i put it all back and the gear lever nothing,my bike was stuck in gear and could not shift up or down.
you have to rock it back and forth to be able to change gears...are you doing this?
Link to comment
Mayb you did not put your gear lever in in original place mayb I had a old pit bike years ago that I done it to and would not go in gear till I got it back in the proper place
Link to comment
Dr rich maybe it could be that,how did you get over that.put it on and check,and if not take off and move slightly and so on was it.
Yep that's how I done it don't take to long next time get a tipex pen and mark it so u no where it lines up if it is that
Link to comment
Normally there is a mark on the splined shaft that needs to line up with the split in the lever
Ride it for a couple of days, if its still good, then mark the end of the shaft with a centre pop, where it lines up with the split. That wont wash off
Link to comment
Airhead and dt rich.thanks for your help,i did what you said rich took 3 attemps but all sorted now thankyou.
Good glad you sorted it :)
Link to comment
  • Recently Browsing
