hi was wondering if any 1 could help me I have a sr125 on a 94 reg and noticed there was quite abit of oil in the air filter box
I take it that's not normal and does any 1 know why this is please
might be worn piston rings causing 'blowby' of compressed gasses into the engine casings, try placing a tube onto the breather and see if you can detect any draught coming from the tube, maybe also mix a 2mm deep soapy solution in a jar and see if the tube blows bubbles there?
The tube will have to be a very good fit on the breather for any of this to work
I'm kinda hoping others will chip in here as all of this is just a guess by me
ok cheers I,ll have a go tomorrow
how easy is the piston rings to change
Ok cheers thought it wouldnt be easy lol to be honest i did check the oil level earlier and i think it was just over the max mark
Is it fresh oil or does it look like its been there a while? Has your bike been dropped recently?
Hi yea its fresh oil, no i havent dropped it but not sure about the prevous owner
If its fresh its most likely to be down to something done recently. I accidentally overfilled mine with oil and had some blowing back. I'm no mechanic - see some of my previous posts - but there are a few of us SR owners on here. Hopefully one of them has had the same issues? If it is the rings that have gone I would imagine you have blue exhaust smoke.
Ok yeah ill have a look around cheers for the help i think the prevous owner has over filled the oil any way so i think im gonna change it this wkend
I had a hell of a job finding the right oil when I changed mine not so long back - make sure you get the right one! You can't just use ordinary 4t oil with a wet clutch. Apologies if it sounds like I'm teaching you to suck eggs but a lot of local garages to me don't sell the right type. Do you know when the oil filter was changed?
Clean out the oil from the box reset the oil level to below max,a over full motor will force out oil.Clean out the vent tube and reinstall.
Then drive it for a week and check to see if the oil is back in the box,if not all is well ....if it is back then have a compression test and a leak down test done to determin the condition of the rings and valve seating
If the bike has been droped this may not have been cleand out after and nothing to worry about.
Thanks for the advice guys not sure when the oil filter was changed and thanks for letting me know about the oil Andrewelvisfan ill give it ago the wkend and let u know how i get on cheers
On a 94 plate sr I would be more worried if there was no oil in the airbox.
At that age there will be some pressure venting. Its how it works, the vapour traps will be gunky now and not as efficient at removing the heavier mist.
As long as were only talking about a couple of capfulls, I would call it normal. Certainly was on my old 600.
Should I be worried then? How's your arm now?
Good as its going to get, just getting old I think. The, 'dont be a wuss' moments crashing off bikes in the fields as a bulletproof teen coming back to bite lol.
