December 14, 201312 yr Does anyone know if you can get to these on this bike. I've followed the normal procedure that worked on my TDM and on the FJR but all I can get on the XVS is the DIAG fields. Thanks
December 26, 201312 yr Hi Bulldog. I'm not sure however you can get the service manual here which might help? http://vstar1300.pbworks.com/w/page/5760692/FrontPage If that doesn't help I'd try asking on this XVS/ V Star 1300 forum http://forums.delphiforums.com/n/main.asp?webtag=vstar1300&nav=start&prettyurl=%2Fvstar1300%2Fstart&gid=2113583361
December 27, 201312 yr Author Thanks Clarke. I've got most of the manuals already and I can't find any reference to checking the CO levels. I think you may have to plug into the ECU. Never mind, it's running ok anyway but I thought I might just check them and possibly have a play since I fitted the Cobra exhaust.
December 30, 201312 yr If it's the slipon then it'll be fine. If it's a full exhaust then I think most people tend to go power commander and aftermarket (open) air filter.
