aerox 50 lc wiring problem
jd9995
This post is 4000 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi I have a aerox 50 lc 06 I got seconded had in a state and rebuild it up spent a fair bit on panels and bits to get it sorted when getting it running the head lights are dim and when rev brighten up I have had a new battery on and is showing full charge I have put a earth straight from the negative side of the battery to the frame think I may be a earth problem I have a TNT aftermarket headlight on it don't sure if this would cause it sins I got it for my model also my speedo has just gone not sure if this a related problem any help would be great
