dt250
Hi I have a dt250 that's in need of a throttle cable can't find one for the 250 but found them for the dt125/175 and the mx250 will any of these work I need the lower half
What year/model etc - does it have the cable for the oil pump and carb?
Have a look at: http://www.cmsnl.com/yamaha-dt250a-1974_model8480/partslist/D-09.html
Part 20 being throttle cable then splits to 2 cables to oil pump and carby(the lower part you're talking about) which is Part #21 - I am unsure if they reproduce these anymore as many don't run oil tanks(just use premix) so they old stock ones are quit expensive
Heres one for $45: http://www.ebay.com.au/itm/Yamaha-DT125-DT125C-1976-Lower-Throttle-Cable-New-NOS-OEM-/400591965526?pt=Motorcycles_Parts_Accessories&hash=item5d45244d56 but I am unsure of the difference between the 125 and 250 cable lengths. Airhead may be able to answer this.
Hope this is of some help.
Its a 1974 dt250a I'm in need of the lower have where it splits one for the carb the other for the oil pump i can find it for the 125 & 175 not 250 or 360. I also can find it for the mx250 just sure if any of these are the same lengh connect the same
Hi Quigleyje,
If you check out the cmsnl website, they show the part number for the item you are looking at for the 250, then check the part number for the same item on the 125/175. If they have the same part number, you can safely interchange them.
Cheers
Mark
