December 2, 201312 yr Hello, I own a 2007 Xt125x, I need to replace the starter clutch, does anyone know if the YBR 125 starter clutch will fit and are they year specific ? Also need to change the chain and sprockets, does any know what's best. Thinking of altering the front sprocket (number of teeth), has anybody tried this ? Cheers Andy.
December 2, 201312 yr Hi andy, starter clutch on most models are three rollers and springs located on back of rotor,, do you have a manual? you"l need a puller if this is the same on XT,,,, and up 1 tooth on front will giv more top end and lesser excelaration, on Yb. best pop an intro in new members section,,,
