bgibbon Posted December 2, 2013 Share Posted December 2, 2013 Hi guys, new to this forum & fairly new to biking, I've had my XT125 on the road for about a month now & I'm finding that the headlight, even on full beam, is very poor at lighting much of the road, I was just wondering if this is common on the xt125 & if anyone can reccomend a way to brighten the light, I'm not sure if I can put a halogen bulb straight in? Link to comment Share on other sites More sharing options...
welshwan Posted December 2, 2013 Share Posted December 2, 2013 the light on mine was bloody useless too! i just got a LED spot light and that was perfect. Link to comment Share on other sites More sharing options...
AndyM46 Posted December 2, 2013 Share Posted December 2, 2013 Hi, had the same problem with my lights, useless!! Brought a 35/35W halogen bulb from Halfords, dip seems a bit better but main is all over the place ( might need a slight adjustment) let you know. Andy. Link to comment Share on other sites More sharing options...
bgibbon Posted December 9, 2013 Author Share Posted December 9, 2013 the light on mine was bloody useless too! i just got a LED spot light and that was perfect. When you say LED spotlight, do you mean the handle bar mounted spot lightsyou can get, or an LED bulb? Link to comment Share on other sites More sharing options...
GoProKid Posted December 30, 2013 Share Posted December 30, 2013 Hi, I have a 2007 XT125X and I know the problem that you are on about. The problem with these bikes is that the parts available are fairly limited so there is no room for any modifications especially with the wiring loom. The front headlight connection, I know (from experience) is a BA20D which is starting to become more uncommon on motorcycles. I bought a 45/40w halogen light and I've never looked back. Its not brilliant but it is most certainly a marked improvement, on full beam and dipped. They're available from ebay, the item number is 231120828933. Link to comment Share on other sites More sharing options...
bgibbon Posted January 3, 2014 Author Share Posted January 3, 2014 Hi, I have a 2007 XT125X and I know the problem that you are on about. The problem with these bikes is that the parts available are fairly limited so there is no room for any modifications especially with the wiring loom. The front headlight connection, I know (from experience) is a BA20D which is starting to become more uncommon on motorcycles. I bought a 45/40w halogen light and I've never looked back. Its not brilliant but it is most certainly a marked improvement, on full beam and dipped. They're available from ebay, the item number is 231120828933. After much hassle, I decided to go with an LED spotlight on a separate switch, it's a massive massive improvement, brighter than most car headlights on the road! Thanks to Welshwan for the suggestion!! Link to comment Share on other sites More sharing options...
welshwan Posted January 3, 2014 Share Posted January 3, 2014 Knew you'd like it, just make sure you switch it off when you meet a car coming the other way though lol 1 Link to comment Share on other sites More sharing options...
AndrewElvisFan Posted January 5, 2014 Share Posted January 5, 2014 Knew you'd like it, just make sure you switch it off when you meet a car coming the other way though lol Unless they have their high/fog lights on when it only rains..... 1 Link to comment Share on other sites More sharing options...
welshwan Posted January 5, 2014 Share Posted January 5, 2014 Unless they have their high/fog lights on when it only rains..... YES!!! Link to comment Share on other sites More sharing options...
bgibbon Posted January 21, 2014 Author Share Posted January 21, 2014 It is very satisfying to blind the bastads that forget about they're high beams, I will admit, finally put up some video footage of the light in use as well!! Watch if you wish, recently started my motovlogging channel 1 Link to comment Share on other sites More sharing options...
AndrewElvisFan Posted January 22, 2014 Share Posted January 22, 2014 I improved my SR125 light with a 40/45 bulb. Not as good as the LED you've got though. What wattage LED have you got? I assume its a Cree LED? Link to comment Share on other sites More sharing options...
blackhat250 Posted January 22, 2014 Share Posted January 22, 2014 Big difference " and that was neutral you hit, not a false. Link to comment Share on other sites More sharing options...
bgibbon Posted January 24, 2014 Author Share Posted January 24, 2014 Occasionally skips back into neutral from second which is what I thought had happened, probably did just hit neutral that time, though.. aha. Link to comment Share on other sites More sharing options...
bgibbon Posted January 24, 2014 Author Share Posted January 24, 2014 I improved my SR125 light with a 40/45 bulb. Not as good as the LED you've got though. What wattage LED have you got? I assume its a Cree LED? Mine is a 20w CREE LED, the 1800 Lumen one. 1 Link to comment Share on other sites More sharing options...
