Dragstar Horn Won't Work
Motorhate
This post is 3961 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Got a problem I noticed this morning with the horn on the bike. It won't work. Not sure where to start on this. I'll admit now, I'm not much of a mechanic but I don't think there's a fuse for the horn in the fusebox. Any ideas or any common causes of the horn not working ? ... (cue Viagra jokes!!).
Start simple mate, take off the wires and clean up the conectors with some WD40 and the rough bit off the wifes kitchen sponge. If no luck then remover the horn and get two wires and connect it direct to your battery if it works then one your get the fright of your life and two you then know you have a wiring problem.
Off the top of my head i cant rememebr if there was/is a fuse for the horn, my manuel is at home at the mo so i cant check for you but start off simple with cleaning the contacts and go from there :thumb:
The last time mine stopped working one of the spade connectors had come loose.
They either work or they don't, horrible bloody things to try and fix best bet the horn is knackered, as above test it wired direct to the battery and make sure you don't have your best under wear on as even when your expecting it it makes you jump !!! some might be fused but none of mine have been over the years so probably not.
Make sure the wires are working and, if so, replace the faggotty little Dragstar horn with something more manly that lets car drivers KNOW they've been spoken to!!! :)
These are nice: http://www.amazon.co.uk/12V-Snail-Air-Horn-Set/dp/B0042EWMFQ
Most bike shops will sell something like this.
Not on my own bike, no, but three of the bikes at work have them and they are giggle-inducingly DEAFENING!!
They were actually on my shopping list, before I had my mishap with the sump seal failure.
Tried a few things - I got a cheap replacement horn (118 db apparently) and it still won't work. I'm beginning to think I might need to replace the switch unit on the handlebar to get it working - joy!!
Admittedly I haven't cleaned the contacts yet so that's next on my list and also to check the wiring into the two spade connectors. Will need to wait until I have some time during daylight hours to do this. I didn't realise how much you miss not having one when riding round London in the rush-hour!
Simple way to check the wires for the horn, get an old working indicator conect it up to the horn wires and push the button, indicator should light up if it does then your horn is at fault. If it dont light up then you have a wireing problem.
If you aint got a spare indicator either remove one off the bike for two mins or find another spare light with wires thats to hand
Give the switch a good few squirts of WD40 and press it lots in between.
That usually helps clean these things up.
If you're feeling handy, take the control cluster assembly apart and give it a proper scrub out.
Thanks for the tip Ttaskmaster's, I'll give that a go if Noise's tip on the indicator isn't working.
Is the switch unit difficult to take apart?
Nope. Should just be a couple of screws on the back.
Make sure you pay a little attention to the alignment when you're reattaching it, though.
IIRC, your wing mirror is also attached to this, so be sure it's not twisted too far round the bar, if that makes sense?
There may even be a little hole in the bar, that a stud on the cluster fits into.
  • 1 month later...
Just thought I'd update you on the horn issue. Well I took Ttaskmaster's advice and squirted a load of WD40 into the switch unit. Nothing, dead as a doornail so resigned myself to buying a switch unit. For some reason, I was watching one on Ebay but never pulled the trigger on it and rode without a functioning horn (mind you, could have done with one on more than one occasion - bloody BMW drivers!). This morning, for some unexplained reason whilst riding down the A40 to work, I decided to try the horn and it actually worked. I was almost as surprised as the bloke in the car driving next to me. So it seem the WD40 did the trick. Thanks Ttaskmaster!
  • 3 weeks later...
Tried those. They work, but they don't fit the dragstar. Having installed only one (there's NO chance of fitting both), whenever I brake, the forks compress, the horn pushes against the front fender which in turn produces a scraping sound as the fender scrapes against the tyre. Waste of 8 quid.
There must be a way to fab up a simple bracket and place them somewhere better...
But TBH, anything will be better than the Drag horn.
It might be possible (not by me - don't have the tools or skill) to fab up a bracket that can place the horn closer to the engine to avoid the fender, but then there's the risk of overheating. Or placing it to the side (which will look stupid!). I think if I ever get the horn changed it will be to a specialised bike one (and therefore more expensive). Maybe something from HH.
Just reading this and thought I would pop in.
most cars use horns of aprox the same size same voltage but are of the french horn ( musical instrument ) style, get 2 and wire them in together and you will piss yourself the first time you hit the button.But everyone else around you will too.
So a quick trip to the auto wreckers and a few bucks and presto you got train loud horns.
PS: they also come with the same style bracket to mount to the forks.
