FJ1200 - Bought 2 LED spots for on the side brackets - wiring in advice ?
Evening chaps,
Bought 2 LED spots. Any howto's or advice how to wire these in.
I could wire into neg somewhere and take pos from rear lights - separate switch ?
Flame away :-)
I was gonna do this myself at some point. Might take me a bit longer, now... But basically:
- Wire into a good earth point.
- Wire the positive into a switched live.
- Include an inline fuse for each spot and wire both through a switch separate to your normal headlight.
I can't tell you the exact wiring points myself, at least not right now.
However, the FJ Owners Club will have a wiring diagram available for all variants, at the massive price of £0.01. You should join them anyway - Membership is about £17 and you get specialist, dedicated FJ expertise as well as the Club shop and all their exclusive parts (pretty cheap, too!)
Check them out:
http://fjclub.co.uk/
http://www.fjcatalogue.com/home.html
Really depends on what you want from them ie. running light (on with the ignition) or switched? Also what wattage are they?
This bike is so easy to maintain as long as you can use a spanner and have a manual.
Got them :hyper:
Angled them slightly down and wide. They throw a wide carpet of bright white light on the road 5 to 8 metres in front of the bike. Literally makes a difference of night and day. And that for 17 quid of tha bay.
Features:
  • 3 LED 1500lum High Power 12V Auxiliary Spot Light
  • Incorporates a cluster of 3 high-powered LED's to achieve a retina searing output up-to 1500 lumens
  • Custom optics result in a beam pattern
  • Good for Electric Cars, Electric Bikes, Motorcycles, Jeep, ATV.4x4 Trucks & Motor Cars
  • 3 High Power LED.
  • Custom Reflector for Best focus & flawless beam
  • 3 x 3W LED Spot = 9W Rated Power Consumption
VROOM? :lol:
Whatever that is, I like it!!
