November 17, 201312 yr Hi new to the forum just purchased a 2003 yanaha dtr125 its a bit rough round the edges but roadworthy this is what ive done to it so far New clutch cable Stripped and cleaned rear caliper was binding Made new rh side powervalve cover as was missing until I can find secondhand replacement New exhaust gasket as was blowing (blowing from rubber connector now). Ordered new mixture screw as old one had snapped and was forced in the hole causing no tickover New sparkplug New battery Repaired clock illumination wiring Things still to do Fix indys as flashing rapidly Fit new mixture screw when it arrives Source and fit standard headlight and fairing (polisport one fitted at the mo but leaves wires exposed and has ba20d bulb fitment) Fit new temp sensor Source andcreplace plastics as current ones are tatty. Find where the blue wire with red stripe plugs into behind headlight Lots to keep me busy lol so will probably need a bit of advice along the way The bike goes like stink abd has the powervalve motor fitted and dep exhaust
November 17, 201312 yr Author On and fix a oil leak comibg fron where the rev gauge cable goes into engine
November 18, 201312 yr Author Thanks turning out to be a bit of project but it only owes me 400 quid so its worth spending a few pennies on
November 18, 201312 yr Author Thanks while oil was draining removed the left panel ro see what was behind it.found the expansion tank which is filthy also someone decided to use a sports bottle cap like you get on bottled water as a cap for the tank lol.might have ro find a replacement bottle and cap also water in rad is a nice clean blue colour wheres water in expansion bottle is clear does this mean the two connected systwms arent mixing will this cause me any problems
