Dt125 throttle cable trouble
I snapped my throttle cable the other day and I have got a new one I've got it all in place but it's not working right it Dosent spring back at all to get it back you need to twist the throttle up and I can't get the oil pump to align right as the cable seems to long when I twist the throttle the oil pump barely moves and I must have the needle in the carb wrong somehow as now petrol pours out the overflow pipe as soon as fuel is switched on is there a certain way to set up the cable as maybe put the carb slide together first or the throttle tube first or does it not matter any help much appreciated
