im repairing the oil pump but i got a few problems,
1st problem is the oil pipe that goes from the oil tank to the pump , i cant fit the black pipe into the clutch cover does anyone know a way of fitting this pipe apart from cutting the ends of the pipe.
2nd i`m not sure which side the oil tank goes on the side of the clutch or the side of the generator (i think its the clutch side)
3rd the cable that goes on the oil pump , does this cable connect to the throttle cable
my bikes mashed up its a 92 frame and parts from a 98 and 96 dtr
Hi,
I get the pipe back through the plastic grommet with a little lubrication, a pair of snipe nosed pliers, and some swearing!
I did contemplate trimming the end of the pipe with a Stanley knife to give it a taper, but have managed without so far.
Can't help with tank location on that bike, but yes the pump cable should connect to the throttle cable somehow.
HTH
Mark
i dont really get wot u mean by "pipe back through the plastic grommet" i have a pic of my pump but i dont know how to upload a pic tot his forum
You'll have to upload the pics to a host like photobucket and then link them here. Check out the FAQ thread for more help. :)()
so the pipe has to fit in the clutch case hole
  • 1 month later...
i still can get the pipe in that gap,
has any 1 done this before
Isn't there a grommet and cutout in the plastic oil pump cover that the main feed pipe goes through?
The oil pump cable should connect to the throttle cable via a junction box underneath the fuel tank.
i looked at the cover , so the oil pipe goes through the plastic oil pump cover and the cable goes through this hole
so is this how the cable and the oil pump have to be
