January 18, 200619 yr Can someone please let me know the colour codes for an RD350 ypvs generator please,or let me know where i can see a wiring diagram. Cheers
January 18, 200619 yr There's some RD stuff on here. After a mail the link started working again http://www.smokeriders.com/Technical/wirin...g_diagrams.html
January 20, 200619 yr there should be three white wires, all in one block connector, from the charging part of the windings ( not crucial which way these go) a light blue wire also in this connector for the neutral light a black wire which is earth ( rubber mounted engine) on the ignition side of things and feeding the CDI box should be; a white/red wire and a white /green for the pulser coil ( the little one on the outside of the rotor) the a red wire (high speed running coil) a brown wire ( common feed between the two) a green wire (low speed running coil) i can supply resistance readings for these if required but i will need the exact model
