This post is 4039 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi all please help.drove to work today all fine then snap my clutch cable lever gave up the ghost.on further inspection noticed that the cable had come out of the enggine casing.wire still in tact and nipple on the end fine.so thought it must have comme lose inside the casing.took gear lever off and casing to expose the inside.now I'm a novice so bear with me,the spring was still there but could see a small lever with posy screw but at the end of it something had come off.not sure what or where the nipple end would go.tention in the little lever when i move it.what part is this called as think this is the part i need.don't have hayes manual.so does anyone have any links i can go to.have a look at what it should look like inside the casing when the clutch cable is in proper working mode.many thanks guys.sorry for life story
  • Recently Browsing
