Powder coating a frame
Bradford_angler
This post is 6529 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
s'pose it is a how long is a piece of string, but how much does it cost to prepare and powder coat a frame and swing arm ?
saw it done on the telly with wheel for a vintage car . . looks quite hard work so guess it is expensive. Also not knowing anything about the process are the different types of coating and is there anything to watch out for ?
and is it specialist for bikes or will I get a similar result from anyone I pull out of the yellow pages ?
Link to comment
Share on other sites
I used triple s in bingley
http://www.triple-s.co.uk/
they have an online price list, do a superb job, just degrease your frame and swing arm and they plug all your holes and blast and paint it. Classic Motorcycle Mechanics use them a fair bit.
drew
Link to comment
Hi mate i used to work for a company that had a powder coaters
and had alot dealings with it and who ever you use make sure
you talk to folk who been there and had work done!!
As if its not done right its a expensive nightmare but a good
hard wearing finish if done right.
And take all bearing of because its baked on after powered
put on and it drieds the bearings and melts any rubber
seals on the bearings.
Link to comment
thanks . . for the info and the prices at SSS don't seem half bad . . I guess I will start with the frame and add a bit at a time ..
if you buy Classic Motorcycle Mechanics they advertise in there and you can get 5% off with the ad, at the very least you end up getting the mag free :P
Link to comment
  • Admin
Make sure that you put bolts in all the threads so they dont all get killed!!! and be very careful when taking the bolts out that you dont slit the coating
Link to comment
triple s plug all the threads for you as part of the service
Link to comment
  • 11 months later...
Triple-s in bingley are brill... they plug all areas that dont require any coating and pride themselves on show quality coatings. The one thing they do ask is for you to remove all oil/grease. They will clean but you will pay for it! They also do not coat office furniture or garden fences so its not an industrial bead blasting your frame gets.
Sorry im not a Yamaha owner but was looking for Triple-s web address and stumbled across this forum.
Cheers and beers
Nigel
Link to comment
  • Recently Browsing
