Posted January 13, 200619 yr Hi Excuse my ignorance just bought a 2004 R1 with no owners handbook need help changing Rev Limiter Flashing light at 7RPM is annoying!
January 13, 200619 yr Hi Chris and welcome. I had the same problem with my 03 model so took it to my local yam dealer, who is really helpful and he changed it for me but I can't remember quite how. I'll try and find out again for you. I know you turn the ignition on and as it goes through the diagnostic self test you hit 1 or 2 buttons below the speedo. It is a step through menu so you have to go through all of the setting to get to the one you want, make your changes and carry on to the end of the menu. If you stop and only do the rev limiter light and switch the ignition off, you won't of changed anything. Leave it with me and I'll get back to you. The other good thing is that you can adjust the brightness of that light which when riding at night is like having someone shine an interrogation lamp in you face. regards Rob..........
February 4, 200619 yr Hi Chris and welcome. I had the same problem with my 03 model so took it to my local yam dealer, who is really helpful and he changed it for me but I can't remember quite how. I'll try and find out again for you. I know you turn the ignition on and as it goes through the diagnostic self test you hit 1 or 2 buttons below the speedo. It is a step through menu so you have to go through all of the setting to get to the one you want, make your changes and carry on to the end of the menu. If you stop and only do the rev limiter light and switch the ignition off, you won't of changed anything. Leave it with me and I'll get back to you. The other good thing is that you can adjust the brightness of that light which when riding at night is like having someone shine an interrogation lamp in you face. regards Rob.......... Hi, I set mine to 100MPH so I know when I am up for a 'ban', if you still need the sequence I'll mail it to you as it's a bit of a drawn out affair to describe if you already have it...Tom.
