Posted October 9, 201312 yr So, i bought this one - http://www.ebay.co.uk/itm/YAMAHA-DT125R-DT125RE-DT125X-DT-125-MITAKA-STD-PISTON-KIT-MADE-IN-JAPAN-/231067701699?pt=UK_Motorcycle_Parts_13&hash=item35ccb551c3 Where should i put that what is in middle in ring on left side? Inside of upper ring or insede of down ring?
October 9, 201312 yr Moderator a few points here The rings are different, the top one has a 'keystone' profile section (it's thinner on the inside circumference than the outside circumference...this on goes into the top groove The other ring is flat in Its profile section, this one goes into the bottom groove but first put in the little springy thing so that the ends are either side of the locating peg You'll notice that the rings have a shape ground into the ends so that they fit correctly around the locating pegs
