When i indicate,my rectifier makes a buzzing noise.also my indicators do not work.what could this be thanks
Bee's Wasp's or Hornet's? :grin:
tinnitus?
tinnitus?
2nd biggest cause of suicide, after terminal illness. dont'cha'know...
are you sure the rectum fryer makes a noise .... I would guess this to be impossible with an RX100 ..... would guess your flasher relay is knackered
My flasher unit is close to my rectifier,so maybe your right its like a hissing noise ok thanks
Oh a HISSING noise, you should have said that first that's snakes.!!!!!!!!!!!!!!
that really sounds like the flasher can .... however if the battery is below par the can will make a noise and the indicators will fail to work...
As the bike is now a bit old the following may help replace the flasher can with a rating less than the original spec .... I.E if the can is rated at 10w replace with an 8w can & bulbs also check the brown wire (with a white trace) to check that there are no dry joints in the loom ....
Ok what do you mean by dry loom etc thanks
no in the loom there are some soldered joints over time they decay and need re soldering ... from memory I think the light brown/white trace has a soldered joint .... check the wiring diagram if you have one
