Project 86 FZ600 - "Black Yamba"
normaly a buck is made, that's how they made the bubble canopies for the ww2 aircraft, heat up the sheet and quickly put around the buck.
  • Replies 728
  • Views 110.2k
Love them lights man! nice and clean with the indicators built it. And again in sexy gloss black!
Thanks buddy!! I searched high and low until I found the perfect tail light... I like how the dual round look matches the headlights. Everything's gotta flow!!
I started making modifcations to the back chassis to attach the tail light, and then mocked up a bracket with some cardboard, which I'm going to take over to the local sheet metal place to get cut, or cut myself, depending on how much they want for the job....then I'll get the bracket welded up on the back (or bolted for now) and paint it all up a nice gloss black.
Untitled by feliks.ca, on Flickr
Surprising what you can achieve with a sausage roll box :eusa_whistle:
Now crack on Feliks
haha oh yeah, anything that works! :D I took my prototype down to the sheet metal place today, they're going to make it up for me for $50 including the material...not bad I'd say!
What type of metal? If they use galvy you wont be able to weld it on.
Just plain 1/16 steel, I figured I'd be painting it black anyway. I might just end up bolting it on anyway, we'll see how it turns out with the tabs I made and how good of a job they do with my prototype.
I'd just bolt it on. You might want to remove it at some point. If you want it permanently mounted later on, bring it by and I'll weld it on for you.
Erum I hope you mean 16 guage steel,,1/16 th is like paper,,, not exacty sure but would be like 28-30 guage steel
Sweet, thanks buddy!
yeah, 16 gauge is what I meant :D
Come on feliks get it right FFS!! :eusa_doh::eusa_whistle:
Haha whatever ya fucker! :D
Got my bracket back already! Quick turnaround time at that shop! Fits absolutely perfect!
Great what a little bit of card can turn into. Get on and paint it and get it on the bike.
Already drilling the holes.... just have to balance working on the bike and getting my real work done! :D
Ok bracket prepped and ready for paint! Going with VHT self priming roll bar and chassis paint, same stuff I used on the rear chassis which it's going to connect to.
I know it's not going to be seen but are you going to rub it down with some wet and dry to get rid of the fat ass syndrome? Its just I see you got some orange peel gong on
No. It's an underbody chassis part, not a finished body piece.... it blends in perfectly with the chassis paint. :D
Everything is mounted up now!
You need a new back tire.
