So according to my haynes manual, I have to remove the frame down tubes from the engine, and then remove the engine, I can't remove them as once piece.
  • Replies 728
  • Views 74.5k
probably, you have to understand that its a 600cc engine in a 400cc frame. very tight for room
Success! Once the frame rails were out it was no problem! Even got my wife to help me take it out!!!! LOL!!!! I call that a success in itself. :D
IMG_2353 by feliks.ca, on Flickr
Now... here's the stripped bolt hole (this is for DT who wanted to see how far apart I should take the engine for the machinist)
IMG_2351 by feliks.ca, on Flickr
IMG_2349 by feliks.ca, on Flickr
Ah!  Cool good to know! :D
Why do I always start a project and then halfway through not have the right tool...  where is my 12mm socket?!?  Do I even have one?? NO.  Why would I have a 12mm....the only one I need right now.... haha
Do you have a metric set of sockets? 12mm is a pretty common size, it should have came with a basic set. Buy it if you need it.
Ok, I'm a page behind - please proceed lol
Posted Image
Posted Image
I think that you have to pull everything down to the surface that has the pooched hole. The machinist will need to see the hole and have access to it for the repair. He'll probably need the section above as well to make sure that he has the hole centered.
Yeah that's what I'm thinking, but at least the bottom end doesn't need to come apart right?
As for the cams... how the hell do I get them out now? The book said to remove the sprockets but Flip said I didn't need to....seems like they're in there really tight even though I removed the tensioner on the back and the front....
Any ideas??
IMG_5702 by feliks.ca, on Flickr
See what looks like nuts on the cam shaft rotate the intake foward this will slacken the chain
Your sure you got the cam tensioner out? the chain between the cams should be slack enough to lift the chain off and rol the cam out to the middel
Forget all that you need to turn the motor over so the lobes arent pushing down the valve/springs open the left cover and turn/rotate over the motor
covers open and it's at TDC....puled the front tensioner out (big long ass piece) and the back one out (just the spring thing on the outside) - is there more?
Slightly rotate it off tdc to slack the chain between the cams
which way?
clock wise
What way am I looking at the motor? as it would be in the bike?
yeah how else can you look at the crank? lol upside down? still be clockwise right? :D
Or you mean what way is the picture?? haha.... Front is down.
clock
Feel the slack in the chain you want that between the cams, hard to put to words
10-4! Just didn't want to turn it if I was going to break something...
