Posted October 1, 201312 yr Hi, I was wondering if anyone knew of a stainless steel alternative for the YBR125 Custom exhaust. I have had two exhausts corrode and fall off in the last 2 years (although the 2nd one was used) i ride all year round and i do know corrosion and rust is an issue with these exhausts. I can see loads of options for the standard YBR125 but not the custom? if anyone has any advise it would be greatly appreciated =)
October 11, 201311 yr Hi Nuggy, if you haven't found one yet you could have a look into the GPR exhaust system - easy to install, stainless steel however not cheap! theres a wide range of aftermarket ones but the GPR one seems to be the most talked about one out there.
