YBR 125 2008 bitching starting problems
Hi can any advise i am having major issues with starting my 2008 YBR2008. turn the key the electric start, fuel pump primes and tuns over without firing. it flashes 1 long and 9 short flashes on the engine managment light. This morning it did not want to start fired a few times and cut out then fired and run. got into work an it wnot stat at all. any suggestion to the engine falt code and potential issues. i have replaced the plug with no change.
thanks for the advice
regards
chris
Code 19 is a common fault with the ybr 125,it's deals with the blue wire to the cdi,check old threads here it's been discused at length.
