Fina gear ratio help needed
eeden01
This post is 4086 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Is there room for a 17 tooth front,[ fouling clutch actuator or casings] , ,either that or drop 2 on the rear,,,, heard you searching for more gears,,,
Depends what you mean by topping out too quick. 47 teeth on the rear is a lot for a road bike.
16 on the front is hardly small. If you have the internal ratios of the gearbox and primary drive with a bit of math you can calculate you speeds @ peak rpm for each gear and choose your preference.
With this engine in a 50 all the std geari.g is pointless.
