neutral switch
Hello,I have a ybr where I have to pull the clutch in to start the bike in neutral and have the side stand up, not a bad thing however I shouldn't have to do it that way, also my neutral light does not come on when in neutral,
any ideas what it could be?
And what is the neutral switch could it be this if it is broken ?
Thanks
Check also the wire to the switch is not broken. if you disconnect the wire to the switch and earth it to the engine case the neutral light should come on. If it does then it does sound like the neutral switch.
Ok thanks guys so basically take the neutral cable of from bike and put onto the engine casing and neatural should display?
yes that is what Tony is saying, pick a clean unpainted part like a casing screw.
