September 7, 201312 yr Hi guys I've just got hold of some "used" panniers for my XVS650A Dragstar Classic. Bargain at around £80 and don't look like they've ever been used. I've got pannier supports fitted to the bike from the previous panniers, but they were throw-over and these are not. Looks like they require mounting directly to the bike, possibly using a specific plate or rail mount. I can't find anything using Google, so thought I'd ask you guys before fabricating something myself. Anyone know what sort of hardware is required for these? (I've not posted this in "wanted" as I'm not wanting any-one's kit, just advice over what people have and where to get it from) Thanks Tom (sorry, tried using the editor to resize the photo but it doesn't save the new size)
September 9, 201312 yr Hi there, They are the same as mine, if you have a look at my intro You will see my photos of the mounts. Hope that helps. Tony
September 13, 201312 yr I bodged my panniers to get rid of the throw over look. A steel plate on the inside and back, riveted together then bolted onto the the bike as per a normal bag. Uses a couple of extra strong washers as well to help the job. Ended up stuck solid and looks good if I say so myself.
September 20, 201312 yr Author Cheers for the replies guys - had a go at them at the weekend. Realised the rails I have are no good as they are angled to help the soft throw-over luggage to site right, but means that these hard panniers hang at the wrong angle. So first things first, some new rails!
