Hi can anybody recommend the best type of fluids for my DT 125 RE
2 stroke engine oil
brake fluid
radiator coolant
And any other I might need many thanks Gerry
buy the best you can afford.. :thumb:
Make sure the 2 stroke is for motorcycles. Some of the forecourt stuff is for chainsaws and generators.
Anything dot4 for the brakes
Coolant has to be ok for aluminium.
Thats it. Personally and it was surprising Halfrauds semi synth bike 2stroke is pretty good.
I use silkolene 2 stroke oil and silkolene gearbox oil, it's not to expensive but it keeps my Dt running sweet! I use silkolene for my forks also, I'm not to sure on coolant!
:thumb: listen to this guy ... i use this also
