1998 R1 Meta 351a Alarm removal
The Meta 351A alarm on my 1998 R1 has died (the internal battery went flat and locked me out) I have removed the alarm but cannot get the bike to run at all now. The starter circuit is dead. I had no wiring diagram for the alarm. Has anyone attempted this before and if so can you please help. The starter/ignition circuit has obviously been modified during the alarm installation and needs bridging somewhere.
I am getting power as far as the starter relay but the starter button does not activate the starter motor.
Any help or suggestions much appreciated.
  • 8 months later...
if you still not sorted this fault out at the back of the loom theres three plugs you need to re,wire ,this is meant to use jumper plugs ,when thay fitted the alarm thay would have removed them you should not be able to get this info for re wireing them but your yamaha dealer will no them you will have to book it in. had the same fault with mine , hope that helps :D
