January 2, 200619 yr Any guides/info on setting up my YZF750R (1994) with ohlins rear. I've had a look through the forums but no joy, or I'm blind and missed it.
January 2, 200619 yr Hi mate I got a yzf750r with rear ohlins and front internals . got it set up by a race team. i am 13 stone ish 5 ,8 if this helps i go out anf have a look at the settings. (put a 3mm spacer on the rear of the ohlin at the rear)
January 4, 200619 yr Author Any guides/info on setting up my YZF750R (1994) with ohlins rear. I've had a look through the forums but no joy, or I'm blind and missed it. Cheers M8 13 stone & 6ft so settings should be OK, much appreciated if you could post the details.
January 6, 200619 yr Admin The best way is to goto a track day, when they are running the free suspension set ups As they have so much experience they can pretty much set it up perfectly first go.
