dtr 125 clutch problems!!
cassidy1989
This post is 4108 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
hello all! im wondering if anyone can help? this bike iv been rebuilding has been in some ones shed for 4 years with very little use!! got it running properly today but when i shift into first.. stalls! iv tried and retried adjusting the clutch on the perch and on the cable near the gear shift! but i was wondering, if it has sat that long with very little use... could the pressure plates or the actually clutch itself be sticking? maybe the clutch springs has stiffened?! any help would be great!! :hyper:
Yep bump start it pull in the clutch and see if it will idle without trying to pull away,then pop the side stand down .
clutch has stuck together thats all.
Rocking in fitzt may fix it. After 4 years prob be. etter to whip off the engine case and separate the plates by hand.
Have you checked the oil level? not enough oil sitting for that long would make it stick together...
