Hi, I want to remove my front floorboards and fit pegs instead but I'm not sure what bits I can take off and what I need to keep to fit pegs when I get some, help anyone??
Normally you just pull out the pivot pins, chuck the pegs on eBay and put the new boards in using the same pivot pins. R-clip or cotter/butterfly pin to keep it in place and job done.
To remove my floor boards i just removed a nut and bolt pulled out the boards, then put the pegs in and put the bolt and nut back on
What are you doing with floor boards?
If your selling them drop me a line, I'm only in Glasgow.
Sorry mate sold them a LONG time ago (back in 2011 i think) little tip tho they are a horrible feeling and if your a bit keen in the corners as i was one day i found that i grounded the board and as it bent up (as they do on springs) i trapped my foot between the board and the gear leaver which wasn't a nice feeling whilst riding round corners
Thanks for the advice. Was getting hooked on adding stuff to the bike. Might leave the boards then.
I've got floorboards if you're still interested, PM me, poss rears too.
