This is how I made a GPS mount for my SYM Citycom. This may help others with scoots with a bag hook. I mounted half of a GPS mount to the bag hook of my scoot. BaghookGPSmount1.jpg these are the parts:1.) half of the GPS mount2.) two home made rubber washers for friction between the GPS mount and the U-bracket.3.) two washers to go under U-bracket4.) home made U-bracket5.) bolt to screw GPS mount to U-bracket BaghookGPSmount2.jpg this is how the U-bracket mount with the two washers underneath. I used the factory bolt to do it. BaghookGPSmount3.jpgBaghookGPSmount4.jpg everything mounted with the mount in the everyday ride "out of the way" position BaghookGPSmount5.jpg GPS mounted with a hair band (what ladies use to make a pony tail in their hair) for safety. BaghookGPSmount6.jpg The bracket is spray painted black and looks professional IMHO. This way you can still use the bag hook and it is not in the way getting on or off. The GPS runs off the Aux power outlet. I put the GPS in a plastic Ziplock bag if it rains to keep it dry.happy Citycoming.....until next time.
is not to down? I mean if you want look on the gps, you completly lose the contact with the road
I have to agree with lallasro not the ideal location for city running,mind you did do a nice clean job.I would make another bracket simmilar
that could fit under the mirror where it attaches to the bar mount then it would be at the right place to get a quick look without haveing to total loose road view.
