YZF 750R poor running
Hello, I've got 1995 YZF 750R (import) don't know where from though.. doesn't seem to want to rev above 9-10k without spluttering and missing, idles rough as well but goes great in between..? Only recently got the exup working, has improved mid range and not so much of a flat spot at 3k, new plugs and caps, (they were shorting) but still hasn't made much of a difference, and carbs have been balanced..alledgedly
Anyone out there struck this before or no of any reasons and cures...? i'm stuck! cheers Pete
is the air box fitted correctly
they can be tricky and any leaks will screw up the high rev fuelling
has it got a dyno jet on it ? are the carbs set corectly? if its an import depending on where its come from has the carbs got the correct jetting ?
when was the valve shims done last ?
might be none of these things but might be worth doing some cheaking
sounds like carbs r full of shit maybe needle and emulsions r shot and defo check the valve clearances :D
valve clearances a defo mine well out about a year ago
but not a job if your not very clued up..
cab balance is a good start best thing to do is get it
on a dyno and let some one do that..
