Kkrumb Posted August 5, 2013 Share Posted August 5, 2013 Hi Everyone, I have a 1992 DT 175 that is pretty much the same as 81 UK model. I have a leak coming from my auto lube pump and have not had a chance to check it out as yet. When I emptied the 2 stroke tank while restoring the bike, I did not bleed the air out of the line when I refilled the tank. I have ridden roughly 1,000km since then. Could this have damaged the pump? Regards, Matthew Link to comment Share on other sites More sharing options...
Moderator Cynic Posted August 5, 2013 Moderator Share Posted August 5, 2013 Unlikely. I would be more worried about the motor. If oil is getting out air can get in. That is not good for the oil supply to the engine. As for not bleeding it..............doh Link to comment Share on other sites More sharing options...
