DT 175 Auto Lube Pump
Hi Everyone,
I have a 1992 DT 175 that is pretty much the same as 81 UK model.
I have a leak coming from my auto lube pump and have not had a chance to check it out as yet. When I emptied the 2 stroke tank while restoring the bike, I did not bleed the air out of the line when I refilled the tank. I have ridden roughly 1,000km since then. Could this have damaged the pump?
Regards,
Matthew
Unlikely.
I would be more worried about the motor. If oil is getting out air can get in. That is not good for the oil supply to the engine.
As for not bleeding it..............doh
