DT 125 headlamp has dimmed
hi,
which bulb out of the two in the headlamp is the dipped headlight?
as recently my headlight when 'dipped' on my dt 125 suddenly dimmed to a point where it is ineffective
can anyone help?
thanks
Ben
Hi Ben, It's normal to do an INTRO (new members section) BEFORE you start asking questions, imagine if you will walking into a strange pub and shouting out your questions to a bar full of strangers, you might get an answer but more likely you will get shown the door, we WONT do that but we might not answer you till you say Hi, not much to ask when you think about it!
Someone on here will no doubt have an answer for your problem but not before you intro yourself.
PS Welcome to the YOC by the way. :jossun:
AS ABOVE, the uppermost bulb should be the dipped bulb by the way, check the earth going to it . the small bulb is the side /pilot/parking bulb.
