Yamaha dtr 125 cdi 2004
Does anybody know we're I can find a dtr 125 cdi from its the type that bolts to the back of the 2 stroke tank off a 2004 engine any help would be great I've looked loads online but can't find a replacement I can get one new from Yamaha near me for £200 but I wanna try find a used working one
I had a similar problem with my Dt. Turns out after buying all sorts of unnecessary replacement parts that it was the generator coil (stator) which had blown due to a damaged flywheel.
Whilst in this predicament i purchased a replacement second hand cdi unit for a 2004-07 Dt 125 which i still have lying about.
I would recommend having the stator (generator coil) checked out by a professional because your CDI is unlikely the cause.
However if you are CERTAIN the CDI is your problem then my spare is up for grabs.
Hope this helps :)
what code is it on the cdi ?
on mine it has 3rm20 325 and ive had the stator and flywheel checked and tested and there fine and how much would you sell for i can collect if your within the uk
