Just a quickie.
While tinkering with me cat i had to change three of the dash lights.
I changed two with 12v 1.7w lamps and fitted a 5w one by mistake.
Although the 5w is brighter and much better, will the do any damage being a higher wattage? :unsure:
Thanks
Thunderass.
wouldnt have thought so aslong as the AMP are the same.
My previous bike was a Cat and shortly after buying it I replaced all the dash bulbs to 5w. Owned the bike for nearly 3 years and put almost 36k on the clock and had no problem from the higher rated bulbs.
Thanks for the advice.
Brighter bulbs it is then. Maybe a shade of blue?
Thunderass. :D
I put some blue ones in my dash and didn't
really make a differance...
Just a thought before you buy some..
I got mine from work so glad didn't
buy them..
